Meaning of the statement in C++?
areeb
Junior Member level 2
What does the following C++ code do??
Hi guys,
I am new to programming, what will be the output of the following code, please respond step by step how will this code work. Thanks!
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
#define reloff PRT1DR &= 0x3a
char d=-20;
void main()
while(1)
    d++;
    if(d==10)
       d=290;
    if(d>1000)
       d=0;
Re: What does the following C++ code do??
The code above seems more complying with C syntax than with C++.
There is no output declared there, so I'm assuming that variable d is what you are interested.
Moreover, there are some possible inconsistencies, such as declaring a variable as char type ( whose magnitude is 8 bits in most uCs ) but you're attempting to store values greater than 255.
Hi, can any please explain what does the following statement mean and what is the purpose? Thanks
#define reloff PRT1DR &= 0x7f
PRT1DR = PRT1DR AND 0x7f
it's a bitwise AND operation
(for each bit of PRT1DR and 0x7f)
and #define is making "reloff" work like compile-time function doing that operation
Reactions: areeb
    areeb
Ahan, and what is PRT1DR? And reloff?? I am not able to find any reference that explains these terms.
reloff in this case is user-defined name - you can use any other valid name you want (as long it's not used somewhere else)
PRT1DR - you need to tell me what is the source of this code and what machine, but it looks like a specific MCU register name...
Reactions: areeb
    areeb
I would guess it's a reference to the port direction bits on a Cypress processor.
"PRT1DR &= 0x7f" means the contents of PRT1DR are ANDed with 0x7F and the result put back in PRT1DR, in other words, bit 7 is made zero with other bits unchanged.
"#define reloff PRT1DR &= 0x7f" just makes a new instruction in your program called 'reloff' which the compiler expands to 'PRT1DR &= 0x7' when it sees it.
So 'reloff' makes bit 7 of PRT1DR become zero.
Generally, we use #define like that to make the program more readable, for example you can use it so a port pin becomes synonymous with what is connected to it. So if you used "#define RelayOn PORTX,6=1" you could use the command "RelayOn" in your code rather than an instruction that didn't describe what it actually did. It also makes it a lot easier to modify the code afterwards. Example: if the relay was changed to bit 5 instead of 6 you only have to change the number in the definition and recompile. Without it you would have to go through the entire code and edit all the occurrences from 6 to 5.
Brian.
Reactions: areeb
    areeb
