meander microstrip antenna
peter-gr
Member level 1
Member level 1
Hellas(Greece)
Does anybody has any publication with a microstrip meander antenna fed by a 50Ω microstrip line.If anybody has such a publication which gives the exact dimensions such a microstrip antenna please post it to me because i have a project to simulate a meander microstrip fed by a microstrip line.
Thank you in advance.
peterpsomos
peterpsomos
Dear peterpsomos,
you probably mean microstrip antenna with trawelling wave (loaded at the end by 50Ohm resistor).
Obviously you will find info in every book dealing with microstrip antennas (like Microstrip antenna design Handbook - I think it's in MCU) under section Antenna arrays or Travelling wave array.
Can you describe more your antenna? It's Franklin-like?
Regards,
Eirp
Hi peterpsomos,
I searched google and found this site:
Cheers,
Element7k
peterpsomos
Reactions: sloty
    sloty
Hi eirp,
meander line antenna is a broad term to use. It can also mean fractal antennas! Have you been doing any more work on that recently?
Cheers,
Element7k
eirp said:
Dear peterpsomos,
Regards,
Eirp
Element7k said:
Hi eirp,
Cheers,
Element7k
eirp said:
Dear peterpsomos,
Regards,
Eirp
Hi, Element7k!
I know it's broad term but usually it's used as Franklin array or to make circular polarization.
Concerning FAs, I'm now busy by another projects :cry: and I'm now only collecting papers.. I hope next year will have more time..
Rgz,
Eirp
