cartman007
Member level 2
Hey guys.
I recently found that a MCU's built in oscillator failed whenever the device went anything under 0 degrees "Celsius"
The Osc worked in LOW power mode and it was at 20Mhz.
When we divided the clock with anything above 2 it seemed to work fine.
Now this is weird since if you divide the clock it doesn't necessarily mean that the oscillator is going any slower...it just gets divided before being referenced to the CPU?
Might it be the CPU being hampered in some way by the COLD?
Why would that happen?
How does COLD weather affect the electronics or functionality of an Oscillator?
