deepshah3
Junior Member level 1
Hi there,
I am facing an issue of MCLR reset in my PIC16F887.I have connected the connected the recommended components as per the datasheet, at the MCLR pin. I am using this chip in a product where we are sensing the mains input voltage. We have used a 12V SMPS to give supply to 7805 to generate the 5V for PIC16F887. However, the circuit is such that the main line Neutral is connected to the 5V ground. Is it possible that, this neutral to 5v ground connection, is creating some problem due to which the MCLR reset occurs?
