csibi
I used this microcontroller: Esp32 TTGO T-Call, this RGB module and this battery.
My problem is the following one:
The microcontroller is connected to the battery, then I connected the RGB module to the microcontroller and I write a simple code to test. It was successful since the RGB module light up. After a while, the microcontroller automatically turned off (battery fully charged) while connected via battery. If I connect that via USB it working well.
My opinion for why is this die (turn off) after a while because the RGB module uses too much current. According to the documentation a GPIO pin can output max 12 mA.
Since now if I upload any kind of code to the microcontroller die from the battery.
Can you help me with this?
Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 void setup() { // put your setup code here, to run once: pinMode(4,OUTPUT); pinMode(5,OUTPUT); pinMode(18,OUTPUT); digitalWrite(4,HIGH); digitalWrite(5,HIGH); digitalWrite(18,HIGH); } void loop() { // put your main code here, to run repeatedly: }
