maximum frequency of clock in MAX7128SLC84-10
kkdelabaca
Full Member level 2
Full Member level 2
HEllo,
I have component MAX7128SLC84-10. The reference "- 10" indicates the maximum delay between the INPUT and OUTPUT pin, is correct?
As it is the maximum frequency of clock that I can use in this device?
Regards,
10 ns is the input to non-registered output delay.
The maximum frequency of your component depends on what you want to put in.
if it is just 2 serial Flip flop, the maximum frequency is 1/10ns = 100MHz
Thanks for your explanation.
I always program with MAXPLUS II. Exists some menu where indicates the maximum frequency that you can use once programmed the device?
Thanks!
Yes it is.
menu : Max plus II / Timing Analyzer
then
menu : Analysis / Registered performance
Click on start and look at the resut. It gives you the worst case timing, so the maximum frequency.
8)
