noureddine-as
Junior Member level 2
I'm synthesizing an RTL block using Design Compiler, for an ASIC target. After analyzing and elaborating the design, then specifying some parameters (clock, input/output delays, operating conditions, wire model, ...) I perform compilation.
Usually I use this one:
But since I needed to retime internal registers to satisfy a higher frequency constraint, plus apply clock-gating to reduce power consumption, I replaced that line with:
However, I always get a max_leakage_power violation at the end (details below), while all the other constraints are met. Can this problem affect my future analyses? especially power analysis (in PrimeTime) in the next steps? should I worry about it? and what could I do to resolve that?
Thanks in advance.
compile -exact_map -ungroup_all
compile_ultra -exact_map -retime -gate_clock
Constraint Cost
max_transition 0.0000 (MET)
max_capacitance 0.0000 (MET)
max_delay/setup 0.0000 (MET)
sequential_clock_pulse_width 0.0000 (MET)
critical_range 0.0000 (MET)
max_leakage_power 0.0079 (VIOLATED)
Thanks in advance.
