rprodrigues
Member level 2
- Joined
- Nov 18, 2006
- Messages
- 49
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Itajubá MG Brazil
- Activity points
- 1,653
max 232 problem
Hi all,
I have been facing some problems with outputs from MAX232 ICs.
I am trying to use an MAX232, a PIC (18F2620) and some other stuff in a circuit to receive data from a GPS by means of an software USART (at 4800 bauds). To do it, I connected one of the pins of the PIC in use do detect the H-to-L variations of the signal do receive. This H-to-L variation is used to trigger the init of the process to receive the serial data.
The problem I realized is that the MAX232 output pin, when there is a voltage of 0 to -12V at the related input PIN, oscillates with a frequency of about 43 kHz.
Is it a regular behavior of the MAX232N IC or it may be any other problem with my circuit?
I have already tested several units of the MAX232N IC, even out of the my circuit, and the output always oscillates when inputs of 0 to -12V are applied.
In my opinion, it is not a problem of my circuits since I am following the manufacturer "typical operation circuit".
Any help would be appreciated,
Rodrigo
Hi all,
Rodrigo
