neal_sampat
Newbie level 1
Hi All,
I am trying to implement matlab scripts for transistor characterisation using the gm/Id method. I have setup the simulator to dump raw results. I am using cds_srr() function from the matlab toolbox provided by cadence to read the raw results. The problem is, the cds_srr() function which, contains a cds_innersrr() mex file, is running only once and during the second run it throws a segmentation violation error even after unloading the mex file using "clear mex". All google search results point me to debug the mex source file using a debugger to find the memory leak, but cadence does not provide the source code for cds_innersrr. Please help me to sort this out, I have been stuck on this for a really long time.
P.S. I am using the 64 bit version of matlab 2013b linux and spectre version is 15.1.0.585.isr10 64bit
