MATLAB program for solar tracker
jaysurati
Newbie level 3
Newbie level 3
I m trying to make solar tracker using MATLAB programming. But don't know how is it possible. how can i install program in controller.
What exactly are you planning to do with your tracker is there any specifications what is the program you have and what controller are you using now
thanx for taking interest in my que....
I use 2 LDRs as sensors, which are continuously send signal to controller and compare with each other. If not equal then controller rotates stepper motor....as these signals continuously checked by controller if they are equal stepper motor does not rotates.
We are using 2 LDRs which are placed both side of panel and according to its signal micro-controller compare its signal. when left LDR is passes high current as compare to left then controller rotates panel left side and will rotate till both the current from LDRs are same. similarly for right side......
