keithong
Matlab Logic Help!
Hi guys,
Will appreciate the help on this quite easy problem that I cant think of any solution at the moment.
Basically I am sensing a voltage with a dsp, and then to output two different values for the sensed voltage. Can I do it thru a form of look up table? Doing a form of feed forward circuit to make an important part of my project stable.
I tried using the if else statements and a multiport, however, I am unable to get the multiport input terminal to be connected to all the 3 if else blocks I have created.
Any help on this is much appreciated! Thanks!
Hi guys,
