MATLAB code needed to create a cellular network
aantaki
Newbie level 3
Newbie level 3
how can i create 27 adjacent hexagonal cells to simulate a cellular network?
the desired picture of the network is attached
you can create a template with variable coordinates and repeat it over and over: plot([0 1 2 3 2 1 0],[1 0 0 1 2 2 1])
Reactions: tamoor
    aantaki
    V
    tamoor
hey thanku for the reply...
i am a no-nothing in matlab...so u have to kindly tell me how do i repeat the plot
Here is a simple code to create an array of cells. Study each function and create your own cell placement.
x_hexagon=[-1 -0.5 0.5 1 0.5 -0.5 -1];
y_hexagon=[0 -sqrt(3)/2 -sqrt(3)/2 0 sqrt(3)/2 sqrt(3)/2 0];
N=10;
M=10;
figure(1)
hold on
for nn=0:N
    for mm=0:M
        plot(x_hexagon+3*nn,y_hexagon+sqrt(3)*mm)
    end
end
for nn=0:N-1
    for mm=0:M-1
        plot(x_hexagon+1.5+3*nn,y_hexagon+sqrt(3)/2+sqrt(3)*mm)
    end
end
hold off
axis equal
thank you a millions time....
Added after 3 minutes:
hey Joannes, i am doing an undergrad thesis on relay enhanced cellular network and i have to simulate a network using my chosen structure and parameters to calculate SINR, pathloss etc. could you kindly refer me any resource that can help me out with this?
I am not an expert in this field. Maybe somebody else in this forum will be able to help you.
hi JoannesPaulus
what you mean by N & M??
if i want to specify radius for the cell how i can ??
and if i want this grid over a certain area in x & y direction how can i specify ???
hi dude how is your thesis progress?
i am currently doing the same undergrad final year proj, running cellular simulation as well but with c++ code.
Do you have any SINR, pathloss resource to share?
Hi if you people have anything regarding this simulation so kindly share with me as i m doing the same project.
how to implement cellular network architecture with matlab ?
help please !!!
Try to design multilayer cellular network may be use to make phantom organ for the biomedical of science and engineering.
