matlab code for SAR(specific absorption rate)
magbach
Junior Member level 2
calculate specific absorbtion rate by matlab
need the matlab code for evaluation of SAR (specific absorption rate)distribution in human head due to cellphone usage using FDTD method
specific absorbtion rate implementation matlab
which technique you used for calculating electric field in the biomedia because for SAR you first calculate the electric field component then SAR calculated ?
after that i will tell you anything about these case.
