tap_delay=[0 10 20 30 40 50];
tap_power_db=[-3.9234 -5.2288 -6.9897 -13.0103 -15.2288 -16.9897];
L=length(tap_delay);
tap_power_lin=10.^(tap_power_db/10);
temp=randn(1,L)+j*randn(1,L);
for k=1:L
h(k)=sqrt(tap_power_lin(k)/2).*real(temp(k))+j*sqrt(tap_power_lin(k)/2).*imag(temp(k));
end
% Calculating average fade duration and plotting envelope of Rayleigh distribution for specified value of fm and ro %
close all
clear all
clc
N=256; %Number of frequency samples
M=8192; %Number of time samples
% Required parameters for INPUT: fm and row (r0)
fm=input('ENTER THE VALUE OF fm [20 Hz, 200Hz]:')
r0=input('ENTER THE VALUE OF r0 [1,0.1,0.01]:')
y=1;
Afd_p=0; % Average fade duration; practical value
Nr_p=0; % Number of Zero-crossing level per second
Rrms_p=0; % Practically calculated R-rms value
while(y<=1)
delta_f=2*fm/N; % Frequency resolution
delta_t=N/(M-1)/2/fm; % Time resolution
%************************* NOTE **********************************%
% "If N=M-1, then the time resolution delta_t=1/2*fm, which may not be
% small so take M >> N. When M > N, we need to pad with zero values
% before taking IFFT."
X1(1)=randn(1); % Generating Gaussain Random with N(0,1)
X1=X1(1);
Y1(1)=randn(1);
Y1=Y1(1);
for m=2:(N/2)+1
X1(m)=randn(1);
X2(m)=randn(1);
Y1(m)=randn(1);
Y2(m)=randn(1);
X(m)=X1(m)+i*X2(m);
Y(m)=Y1(m)+i*Y2(m);
end
for m=1:(N/2)+1
X(M-m+1)=conj(X(m+1));
Y(M-m+1)=conj(Y(m+1));
end
% Sample Se(f) Spectrum
for jj=1:N/2
SeF(jj)=1.5/(pi*fm*(sqrt(1-((jj-1)*delta_f/fm)^2)));
end
% Calculating Edge Value by extending the slope prior to passband edge to edge
SeF((N/2)+1)=SeF(N/2)+SeF(N/2)-SeF((N/2)-1);
for m=1:N/2
SeF(M-m+1)=SeF(m+1);
end
for m=1:M
X_shaped(m)=X(m)*sqrt(SeF(m));
Y_shaped(m)=Y(m)*sqrt(SeF(m));
end
X_component=real(ifft(X_shaped)); % Only considering the real part
Y_component=real(ifft(Y_shaped));
%************* Find R-rms value and envelope of Rayleigh Distribution ***********%
R=sqrt(X_component.^2+Y_component.^2);
r=20*log10(R);
rms=sqrt(mean(R.^2));
Rrms=20*log10(rms);
level=20*log10(r0*rms);
R=r-Rrms;
figure
plot(1:8192,R,'r')
xlabel ('Time Samples, M=8192');
ylabel ('Instantaneous Power dB');
title ('Figure(1):Rayleigh fading signal for Specified fm & r0 ');
% Calculating (Practically) Number of Zero Level Crossing and Average Fade Duration %
h=1;
c=0;
C1=0;
NUM=0;
while h<=M
if r(h)<=level
i=h;
while i<=M
if r(i)>=level
NUM=NUM+1;
break;
end
i=i+1;
end
c=i-h;
C1=C1+c;
h=i-1;
end
h=h+1;
end
Afd_p=Afd_p+(C1/NUM)*delta_t;
Nr_p=Nr_p+NUM*delta_f;
Rrms_p=Rrms_p+Rrms;
y=y+1;
end
%************ Theoretical calculation of Number of Zero Level Crossing (Nr) and Average Fade Duration ************* %
Nr_theoretical=sqrt(2*pi)*fm*r0*exp(-r0^2);
z1=exp(r0^2)-1;
z2=r0*fm*sqrt(2*pi);
Average_fade_duration_theoretical =z1/z2;
rowdb=10*log10(r0) ;
Rrms_theoretical=Rrms+rowdb;
%*********************** Displayiing Calculated values ************************ %
Nr_practical=(Nr_p);
Nr_practical
Nr_theoretical
Average_fade_duration_Practical=(Afd_p);
Rrms_Practical=Rrms_p
Rrms_theoretical
ahmedseu said:% Calculating average fade duration and plotting envelope of Rayleigh distribution for specified value of fm and ro %
close all
clear all
clc
y=1;
while(y<=1)
X1=X1(1);
Y1(1)=randn(1);
Y1=Y1(1);
for m=2N/2)+1
X1(m)=randn(1);
X2(m)=randn(1);
Y1(m)=randn(1);
Y2(m)=randn(1);
X(m)=X1(m)+i*X2(m);
Y(m)=Y1(m)+i*Y2(m);
end
for m=1N/2)+1
end
for jj=1:N/2
end
for m=1:N/2
end
for m=1:M
end
r=20*log10(R);
Rrms=20*log10(rms);
R=r-Rrms;
figure
plot(1:8192,R,'r')
h=1;
c=0;
C1=0;
NUM=0;
while h<=M
if r(h)<=level
i=h;
while i<=M
if r(i)>=level
NUM=NUM+1;
break;
end
i=i+1;
end
c=i-h;
C1=C1+c;
h=i-1;
end
h=h+1;
end
Rrms_p=Rrms_p+Rrms;
y=y+1;
end
z1=exp(r0^2)-1;
Nr_practical
Nr_theoretical
Rrms_theoretical
function [c t]=Rayleigh_Calculation(fd)
So=16; %Number of paths
Fs=1000;
Ts=1/Fs;
tstart=0;
tend=2;
t=[tstart:Ts:tend];
wm=2*pi*fd; %Maximum shift
fm=wm/(2*pi); %Doppler shift
S=2*(2*So+1);
Xco=(1.414*cos(wm*t));
Xso=0;
sum1=0;
sum2=0;
for n=1:So
A(n)=(2*pi*n)/S; %Azimuthal angles
wn(n)=wm*cos(A(n));
O(n)=(pi*n)/(So+1);
sum1=sum1+(cos(O(n)).*cos(wn(n)*t));
sum2=sum2+(cos(wn(n)*t).*sin(O(n)));
end
Xc=2*sum1+Xco;
Xs=2*sum2+Xso;
c=(1/sqrt(2*So+1))*(Xc+j*Xs);
%=============================== fading channel===============================
function [fading]=corr_fading(total)
%Function for generating fading Rayleigh using Jakes model.
o_start=rand(1,1)*10;%First point of random observation.
alpha=pi/4;
N0=8;%low frequency oscillator equal omega_n.
N=(2*N0+1)*2;
sample=total; %Length of data .
n=[1:N0]';
beta_n=n*pi/(N0+1);
%Light velocity.
c=3*10^8;
%carrier frequency.
fc=5*10^9;
%Symbol period.
T=64*10^(-5);
%User velocity.
v=30;
%angle of Antenna .
theta=0;
%Doppler frequency.
v_c=v*(1000/3600);
%v_c=900;
omega_d=2*pi*v_c*fc/c*cos(theta);%Doppler Shift.
omega_n=omega_d*cos(2*pi*n/N);
delta_t=T*1000;
%Observation time.
t=[o_start+delta_t:delta_t:o_start+delta_t*sample];
for k=1:N0
temp_x_c(k,:)=cos(beta_n(k))*cos(omega_n(k)*t);
temp_x_s(k,:)=sin(beta_n(k))*cos(omega_n(k)*t);
end
x_c=(sum(temp_x_c)*2+(2*sqrt(2)*cos(alpha)*cos(omega_d*t)))/(N0);
x_s=(sum(temp_x_s)*2+(2*sqrt(2)*sin(alpha)*cos(omega_d*t)))/(N0+1);
fading=sqrt((x_c.^2+(x_s.^2)*i)/2);
figure(3);
plot([1:sample]*T,10*log10(abs(fading))), axis([0 sample*T -20 10])
title(['Rayleigh Fading channel modelling using Jakes, f_d=',num2str(v_c),'Hz, T_s=',num2str(T),'s']);
xlabel('time[s]'),
ylabel('Magnitude[dB]')
clear all;
clc;
% OFDM Parameters
N=256; % Total number of Subcarriers
ofdmBW=2.5e6; % OFDM Bandwitdh
deltaf=ofdmBW/256; %data on each subcarriers
Tfft=1/deltaf; % ifft period
Tgi=Tfft/4; %guard interval duration duration of cyclic prefix 1/4rth portion of ofdm symbols
Tsignal=Tgi+Tfft; %total duration of BPSK-OFDM symbols=guard time+ifft period
Ncp=N*Tgi/Tfft; %number of symbols allocated to cyclic prefix
nbitspersymbol=N; % For BPSK, the number of Bits/Symbol is the same as N
% Simulation Parameters
samples=10; %Number of the OFDM Symbols to transmit
EbNOdB= 0:20; % Bit to noise ratio
EsNOdB = EbNOdB + 10*log10(N/N) + 10*log10(N/(Ncp+N)); % Symbol to Noise Ratio
SimulatedBER = zeros(1,length(EsNOdB)); %Place Holder for Simulated BER
TheoreticalBER = zeros(1,length(EsNOdB)); %Place Holder for Theoretical BER
% Monte Carlo Simulation
for i=1:length(EsNOdB),
%Transmitter
data=randint(1,N*samples); % Generating Random Data
A=reshape(data,samples,N); % Serial to Parallel
s=2*A-1; % BPSK Modulation (1=1 & 0=-1)
d_ifft=ifft(s); % Applying IFFT
ofdm_signal=[d_ifft(:,N-Ncp+1:N) d_ifft]; % Cyclic Prefix
[rows cols]=size(ofdm_signal);
%Parallel to serial conversion for transmission
ofdm_signal=reshape(ofdm_signal.',1,rows*cols);
%Channel Modeling
%Zero mean unit variance AWGN channel
nTap = 10;
ht = 1/sqrt(2)*1/sqrt(nTap)*(randn(samples,nTap)).';
%%convolution of each symbol with the random channel
for j = 1:samples;
[COLOR="#FF0000"]xht(j,:) = conv(ht(j,:),ofdm_signal(j,:));[/COLOR]
end
ofdm_signal = xht;
noise=1/sqrt(2)*(randn(1,rows*cols));%%%+1i*randn(1,rows*cols));% i components i wont add as its BPSK signal%%))_
%Tdata= sqrt((N+Ncp)/N)*ofdm_signal + 10^(-EsNOdB(i)/20)*noise;
% % Tdata= sqrt((N+Ncp)/N)*ofdm_signal + 10^(-EsNOdB(i)/20)*noise;
%Receiver
RecDataP=reshape(ofdm_signal.',(N+Ncp),(samples+nTap-1)).'; % Serial to Parallel Conversion
% Removing Cyclic Prefix
RecDataP=RecDataP(:,Ncp+1:(N+Ncp));
% FFT
R_Freq=fft(RecDataP);
%BPSK Demodulation
R_Freq1= reshape(R_Freq,1,samples*N);
R_Freq1(R_Freq1>0) = +1;
R_Freq1(R_Freq1<0) = 0;
s_cap=R_Freq1;
RecSymbols=reshape(R_Freq1,1,N*samples); % Parallel to Serial Conversion
numErrors=sum(xor(RecSymbols,data)); % Count Number of Errors
SimulatedBER(i)=numErrors/(samples*N);
TheoreticalBER(i)=(1/2)*erfc(sqrt(10.^(EbNOdB(i)/10)));
end
% Results
figure
plot(EbNOdB,SimulatedBER,'r-o');
hold on;
plot(EbNOdB,TheoreticalBER,'k*');
grid on; title('BER Vs SNR(db) for OFDM with BPSK Modulation Over AWGN Channel');
xlabel ('Eb/No (dB) - Samples = 1000');ylabel ('BER');legend ('simulated','theoretical');
