matlab code for parallel to serial converter
abdullah gill
Member level 1
Member level 1
pakistan
function y=abc(x)
[r,c]=size(x);
a=[-1:c-2];
f=zeros(1,r*c);
for i=1:c
forj=1:r
f(i+j+a(i))=x(r,c-(i-1));
end
end
Try this Abdullah,
Assuming your Parallel stream of data is stored in a variable ParStream, then you can convert it into a serial stream as,
SerStream = reshape(ParStream,1,[])
thanks for the help but the problem is i have to use the code in system generator block so i cant use the inbuilt commands of matlab........can u help me in system generator
this is a very useful notation for me, it will help me in the nearest future. May be in the future i will use the FPGA board but for now, may be i can help in matlab, tell me with a numerical example how you want to convert?
for example:
Reshape a 3-by-4 matrix into a 2-by-6 matrix.
A =
1 4 7 10
2 5 8 11
3 6 9 12
B = reshape(A,2,6)
B =
1 3 5 7 9 11
2 4 6 8 10 12
B = reshape(A,2,[])
B =
1 3 5 7 9 11
2 4 6 8 10 12
or do you want your serial data (one dimension) to be in parallel (rows)?
tell me
thanks
Added after 43 minutes:
any way: i did this code for you:
%% parallel to serial
clc;
clear all;
close all;
a=[1 2 3 4;5 6 7 8;9 10 11 12;13 14 15 16;17 18 19 20]
r=length(a:),1))
aser=[];
for l=1:r
aser=[aser,a(l,:)];
end
aser
results:::::::
a =
1 2 3 4
5 6 7 8
9 10 11 12
13 14 15 16
17 18 19 20
r =
aser =
Columns 1 through 14
1 2 3 4 5 6 7 8 9 10 11 12 13 14
Columns 15 through 20
15 16 17 18 19 20
best regards
