HarveyH43
Newbie level 3
Mathmatic nightmare...
Well, I'll admit this is a little weird and out of place, but figured I'd give it shot.
I'm trying to buid a small pyramid with concrete, as a headstone. Inbeded in one side will be a small LCD screen displaying a slideshow of some photographs.
The concrete form is way out of my league, but managed to learn what I need to calculate the volume of the pyramid and how much concrete I'll need. But, I have no idea how to go about figuring the the angles I'll need for the edge cuts on the plywood form. When I first got this idea, I figured a 45 degree angle, like a picture frame (four sides, half the 90 degree corners). But, as I get closer to actually start construction, the feel that it's not quite right gets stronger.
I'm thinking that the base angle of the pyramid will need to be considerd in the angle cuts on the plywood....
Anyway, the base is 36 inches square, each side is an equalateral triangle. The form will be built lay on one side (front suface). The backside facing up an parallel to the ground I'll need 36 inch square for the base, and 3 triangles. The edges most meet cleanly. The base square is simple, half the base angle, but the triangles....
Yeah, it will weigh a lot, but I'm guessing that it will be sitting near equalibrium, and I should be able support or anchor as needed. After concrete cures, just remove the base square, and let gravity do the rest, with minimal help
Oh, guess I should mention, it's a marker for my dog... But still an interesting challenge if you good with math. Any help would be appreciated. As you can imagine, not something with many resources on the web...
