MathCad bode plot (100pts) solved
max0412
Full Member level 5
Full Member level 5
bode plot using mathcad
How would you make a bode plot of the transfer function below G(s) in MathCAD? It is the control to output for a fly back converter.
I’ve been trying some examples from the internet but I keep getting errors.
This is the example I’ve been trying to follow.
http://users.ece.gatech.edu/~tbrewer/ece3041/Lecture_Notes/Mathcad%20Tutorial.pdf
Edit never mind I figured it out.
I'll post the solution here if anyone else has the same problem with MathCad. See below.
