what is mean? Can you tell detail?layes2 said:just use odd one not even
Dear,kapils1982 said:The gaurd rings will not help matching because the gaurd ring will only consists of matals and will not efeect eatching of poly and other layers .
We can improve the right form by placing dummy transistors all over the boundary
Don't forget that matching means also proximity. The more your device are close the best it is.franck said:"The gaurd rings will not help matching because the gaurd ring will only consists of matals and will not efeect eatching of poly and other layers ."
But guardring consists of active by definition and so it will help to tie well the substrate and so have quite the same parasitic capacitance to substrate. It seems You need a good guardring if you are looking to have the best matching.
In the last picture the dummies between your 4 block devices in Y and X can be reduce to one row and column. And You can certainly delete them by separating all your device with the same lenght. Don't forget that matching means also proximity. The more your device are close the best it is.
kapils1982 said:Dear
I need some clarification:
when u say 48 current sources do u mean that u have 48 separate current sources
OR
Do u have 12 current source for ur DAC with 1 2 3 4 comprising of one current source and so on..............
thanks
kapil
