Matching of diode impedence in Mixer design
zeshan102
Full Member level 1
Heart of Pakistan
how to measure the diode on and off resistance in ADS and which resistance is used to match the coupler if this diode is used for mixer.
I think you will need to find the matching circuit using nonlinear model for the diode and HB simulator.
flyhigh
i think you can use the large-s parameter method
zeshan102 said:
how to measure the diode on and off resistance in @DS and which resistance is used to match the coupler if this diode is used for mixer.
Could I know what you mean by the large s-parameter method?
Thanks.
here is a paper for your reference...
Hello guys,
I've done the same project b4 in ads, u can simply use any HB simulation controller, in my case i ve used LSSP (large signal s-parameters) & it worked effeciently, but u ve first to perform a nonlinear modeling of the diode used.
good luck :wink:
momo
