usman_mahfooz
Member level 2
microstrip transmission lines
i have a component (RFMD IC 50 Ohm matched) which i will solder on a pcb with transmission line width of 1.5 mm (50 ohm impedance).
The legs of that component is .5 mm long so it will be soldered like this
So it covers half the transmission line. Will there be any problem of matching as component leg in not covering the whole width of transmission line
Kindly comment URGENT
