Matched Instances with bad net connection
Chinku_420
Newbie
I am designing a conventional cross-coupled VCO and I connect the VCO output with the buffer (Simple source follower).
When I ran the Assura LVS, I got one error: "Matched Instances with Bad Net connection". I tried to solve this error still exists.
Your help will be highly appreciated.
Thanks
Use debugging tools available in Assura LVS to trace the bad net connection. The error report usually indicates which nets or instances are problematic. Follow these hints to narrow down the issue.
LaTeX Commands Quick-Menu:
