Marble flooring Lighting Project.
Prashantakerkar
Member level 4
Member level 4
Is it feasible to have Lighting under Marble flooring?.
I.e. Electricity cables layed inside the Marble floor along with diferent colour Tubelights, Chandelier Led Design concept etc?.
If yes,some designing ideas contributed is greatly appreciated.
If no,what will be the limitations to achieve this function?.
Thanks & Regards,
Prashant S Akerkar
Thanks & Regards,
Prashant S Akerkar
I did not think it was possible but a 5 second google search shows several companies that do this already. Marble is cut very thin so light will penetrate. Just search " backlit marble".
Thanks.
I can lay electrical wires inside the marble flooring with the Tube lights, LEds ?.
Is it worth installing the Marble floor lighting technology in International & Domestic Airports ?.
I really couldn't say how the floor lighting is installed. For counter tops I see there's a a product called " SLABlite". It seems to be a led light spreader. It can be cut and fit on the job site. There are also YouTube videos on backlit marble and onyx. Maybe you can find some information on installation there also.
Yes, you can do it. I went to Yale for architecture school and we even had a building that the entire façade was stone and the exterior light went through and lighted the interior of the library.
"The white, gray-veined marble panes of the exterior are one and one-quarter inches thick and are framed by shaped light gray Vermont Woodbury granite. These marble panels filter light so that rare materials can be displayed without damage" (Beinecke Rare Book & Manuscript Library Website).
If you do a image search for "beinecke library" you will find a lot of pictures of the light going through the stone.
