library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity random is
generic ( width : integer := 32 );
port (
clk : in std_logic;
random_num : out std_logic_vector (width-1 downto 0) --output vector
end random;
architecture Behavioral of random is
begin
process(clk)
variable rand_temp : std_logic_vector(width-1 downto 0):=(width-1 => '1',others => '0');
variable temp : std_logic := '0';
begin
if(rising_edge(clk)) then
temp := rand_temp(width-1) xor rand_temp(width-2);
rand_temp(width-1 downto 1) := rand_temp(width-2 downto 0);
rand_temp(0) := temp;
end if;
random_num <= rand_temp;
end process;
end;
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
--use ieee.std_logic_arith.all;
use ieee.numeric_std.all;
entity mapper_1 is
port (
clk: in std_logic;
data_in : in std_logic_vector (9 downto 0);
data_out : out std_logic_vector(10 downto 0)
end mapper_1;
architecture mapper_arch_1 of mapper_1 is
--default state
constant min_count : integer :=0;
--signal one : std_logic_vector(0 downto 0) :="1";
constant max_count : integer :=511;
begin
process(clk)
variable cnt : integer range min_count to max_count;
variable n : integer :=0;
begin
cnt:=0;
cnt :=cnt +1;
if cnt < 8 then
--if data_in < 8 then
data_out <="00000000000";
end if;
if cnt = 9 + 10*cnt then
data_out <="11111111111" ;
end if;
if cnt = 14 + 10*(cnt+1) then
data_out <="01010101010";
end if;
--cnt := cnt +1 ;
--n := n + 1;
end process;
end mapper_arch_1;
cnt:=0;
cnt :=cnt +1;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 signal clk, rst : std_logic; signal cnt : unsigned(7 downto 0); -- counter code process (clk, rst) begin if (rst = '1') then cnt <= (others => '0'); elsif rising_edge(clk) then cnt <= cnt + 1; -- or it might require cnt + to_unsigned(1) (I'm not a big VHDL user) end if; end process
use IEEE.std_logic_arith.all;
entity mapper_1 is
port (
clk, rst: in std_logic;
data_in : in std_logic_vector (3 downto 0);
data_out : out std_logic_vector(27 downto 0)
--data :out std_logic_vector(30 downto 0)
end mapper_1;
constant begining : integer :=000000001;
constant ones : integer := 1;
signal cnt : unsigned (9 downto 0);
signal data_out1 : std_logic_vector (12 downto 0);
signal data_out_2 : std_logic_vector (17 downto 0);
signal data_out_3 : std_logic_vector (22 downto 0);
begin
process(clk,rst)
begin
if (rst ='1') then
cnt <= (others =>'0');
cnt <= cnt + 1;
if cnt =8 then
data_out1 <= conv_std_logic_vector(begining,9) & data_in;
elsif cnt = 13 then
data_out_2 <= data_out1 & conv_std_logic_vector (ones,1) & data_in;
elsif cnt = 17 then
data_out_3 <= data_out_2 & conv_std_logic_vector (ones,1) & data_in;
elsif cnt = 21 then
data_out <= data_out_3 & conv_std_logic_vector (ones,1) & data_in;
end if;
end if;
end process;
end mapper_arch_1;
elsif cnt = 21 + cnt *3 then
entity mapper_1 is
port (
data_out_1 :out std_logic_vector(2 downto 0)
end mapper_1;
begin
process(clk,rst)
begin
if (rst ='1') then
cnt <= cnt + 1;
if cnt =8 then
elsif cnt = 13 then
elsif cnt = 17 then
elsif cnt = 21 then
data_out_1 <="001"
end if;
end if;
end process;
end mapper_arch_1;
----mapper
--signal_out[0000001data1data1data.......100000000]
library ieee;
entity mapper_1 is
port (
data_in : in std_logic_vector (31 downto 0);
data_out : out std_logic_vector(511 downto 0)
--data_out_n : out std_logic_vector (1 downto 0)
end mapper_1;
--constant min_count : integer :=0;
constant begining : std_logic_vector :="000000001";
constant ending : std_logic_vector := "00000000";
constant ones : std_logic_vector := "1";
--constant max_count : integer :=511;
signal cnt : integer range 0 to 511;
signal data_out_1 : std_logic_vector (8 downto 0);
signal data_out_2 : std_logic_vector (41 downto 0);
signal data_out_3 : std_logic_vector (74 downto 0);
signal data_out_4 : std_logic_vector (107 downto 0);
signal data_out_5 : std_logic_vector (140 downto 0);
signal data_out_6 : std_logic_vector (173 downto 0);
signal data_out_7 : std_logic_vector (206 downto 0);
signal data_out_8 : std_logic_vector (239 downto 0);
signal data_out_9 : std_logic_vector (272 downto 0);
signal data_out_10 : std_logic_vector (305 downto 0);
signal data_out_11 : std_logic_vector (338 downto 0);
signal data_out_12 : std_logic_vector (371 downto 0);
signal data_out_13 : std_logic_vector (404 downto 0);
signal data_out_14 : std_logic_vector (437 downto 0);
signal data_out_15 : std_logic_vector (470 downto 0);
signal data_out_16 : std_logic_vector (503 downto 0);
signal data_out_17 : std_logic_vector (511 downto 0);
begin
process(clk,rst)
--variable temp_out : std_logic_vector(511 downto 0);
--variable temp_out_1 : std_logic_vector(12 downto 0);
begin
if (rst ='1') then
cnt <=0;
cnt <= cnt + 1;
--for i in 0 to 511 loop
--if cnt = 0 then
--temp_out_1 := conv_std_logic_vector(borders,8) & conv_std_logic_vector(ones,1) & data_in;
--data_out_1 <= temp_out_1;
--elsif cnt = 502 then
--temp_out := data_out_1 & conv_std_logic_vector(borders,8);
--data_out <= temp_out;
--elsif cnt =9 then
--temp_out := conv_std_logic_vector(ones,1) & data_in & conv_std_logic_vector(ones,1);
if cnt =9 then
data_out_1 <= begining;
elsif cnt = 42 then
data_out_2 <= data_out_1 & data_in & ones;
elsif cnt = 74 then
data_out_3 <= data_out_2 & ones & data_in;
elsif cnt = 107 then
data_out_4 <= data_out_3 & ones & data_in;
elsif cnt = 140 then
data_out_5 <= data_out_4 & ones & data_in;
elsif cnt = 173 then
data_out_6 <= data_out_5 & ones & data_in;
elsif cnt = 206 then
data_out_7 <= data_out_6 & ones & data_in;
elsif cnt = 239 then
data_out_8 <= data_out_7 & ones & data_in;
elsif cnt = 272 then
data_out_9 <= data_out_8 & ones & data_in;
elsif cnt = 305 then
data_out_10 <= data_out_9 & ones & data_in;
elsif cnt = 338 then
data_out_11 <= data_out_10 & ones & data_in;
elsif cnt = 371 then
data_out_12 <= data_out_11 & ones & data_in;
elsif cnt = 404 then
data_out_13 <= data_out_12 & ones & data_in;
elsif cnt = 437 then
data_out_14 <= data_out_13 & ones & data_in;
elsif cnt = 470 then
data_out_15 <= data_out_14 & ones & data_in;
elsif cnt = 503 then
data_out_16 <= data_out_15 & ones & data_in;
elsif cnt = 511 then
data_out <= data_out_16 & ending;
--data_out <= conv_std_logic_vector(begining,9) & data_in& '1'&data_in;
--if cnt < 8 then
-- data_out <="00000000000";
-- end if;
--if cnt = 9 then
-- data_out <="11111111111" ;
-- end if;
--if cnt = 10 then
--data_out <="01010101010";
--end if;
--cnt := cnt +1;
--data <= data_out+data_out;
--end if;
end if;
--end loop;
end if;
end process;
end mapper_arch_1;
Error (119027): Design requires 546 I/O pad resources -- too many to fit in 544 available in the selected device or any device in the device family
Error (119003): Cannot find device that meets Compiler settings specifications
Error: Quartus II 64-Bit Fitter was unsuccessful. 2 errors, 0 warnings
Error: Peak virtual memory: 953 megabytes
Error: Processing ended: Wed Aug 10 09:59:51 2016
Error: Elapsed time: 00:00:02
Error: Total CPU time (on all processors): 00:00:03
Error (293001): Quartus II Full Compilation was unsuccessful. 4 errors, 33 warnings
library ieee;
--use ieee.numeric_std.all;
entity mapper_2 is
port (
clk,rst : in std_logic;
data_in : in std_logic_vector (2 downto 0);
data_out : out std_logic_vector(14 downto 0)
end mapper_2;
architecture mapper_2_arch of mapper_2 is
--signal rst : std_logic;
signal cnt : unsigned(8 downto 0);
constant zeros : std_logic_vector :="000";
constant zero : std_logic_vector := "0";
signal out_t : std_logic_vector(3 downto 0);
signal out_t_1 : std_logic_vector(7 downto 0);
signal out_t_2 : std_logic_vector(11 downto 0);
begin
-- counter code
process (clk, rst)
begin
if (rst = '1') then
cnt <= cnt + 1;
if cnt = 3 then
out_t <= zeros & ones;
elsif cnt = 7 then
out_t_1 <= out_t & data_in & zero;
elsif cnt = 11 then
out_t_2 <= out_t_1 & data_in & ones;
elsif cnt = 15 then
data_out <= out_t_2 & zeros;
-- end if;
end if;
end if;
end process;
end mapper_2_arch;
