mrestimator
Newbie
A low cost way to manually temporarily switch over from a grid-tied system to off grid without sending power to grid.
I want to be knowledgeable before I have an electrician handle this. I have a 2.4 K solar panel system of 10 panels and an inverter to a grid-tied system. Because the power very infrequently goes out and lasts less than a day, I would like to manually switch and divert the the feed coming down into the grid inverter, into a small backup 120 volt inverter connected to an 20 amp outlet box. I can run extension cords to freezer and refrigerator.
It should be safe to anyone working on the grid even if I manually switch it back and forth since, if the grid power is off, once the manual switch sends the power to the grid inverter, that inverter is already set up not to send power to the grid unless it senses power from the grid.
This backup system will be much less expensive than replacing the current setup with a automatic AC coupling inverter or other non- automatic hardware.
If this is feasible, do I have to worry about the panels producing more power than I'm using? Could someone give me some insight on what hardware is needed?
Thanks
Thanks
