Jademobile
Newbie level 6
Dear Sir,
Manipulation of S-parameters from a dataset and re-assemblying them to a new dataset.
I just want to realize such effect:
1, load a dataset from DAC.
2, Extract S-parameters from the dataset.
3, Do some manipulations to each element of the S-parameters. Such as conjugate.
4, Re-assembly the new elements to a new S-parameters, then finally a new dataset.
5, Above effects should be realized by AEL at best. AEL in Var or Eqn module is fine.
I could load the elements of each element of the S-parameters from a dataset form a DAC, then the following Var module:
file{DAC1, "S[1,1]"}... similar for the rest.
Plz tell me how to realized the whole effects.
Thank you.
Jade
Thank you.
Jade
