making leds glow and off using gsm and avr microcontroller
sravani.thatha
Newbie level 6
Newbie level 6
India
hai,
i am trying to read the message we sends to gsm modem and perform accordingly,and immediatly needed to delete the message and gsm must be ready to receive new sms and should perfrorm the given action..and it must continue forever.........
and now i am able to do the thing once.
i mean i send an sms and performed action accordingly.........but i am little bit confused how to make it as an infinite loop.........
so plz kindly suggest me the way to make it infinite.......
while(1){
// your code here
i can use while(1) or for9;;) for making it an infinite loop but the problem is when ever i send command for reading an sms i.e.. AT+CMGR=1 the LEDs went off but i need to continue the previous state of LEDs until new sms found in the inbox which make the LEDs off.........
plz suggest an idea to make it possible..........
Just compliment the state of the LEDs after your use of blinking it & put this routine in an infinite loop.
Regards,
Jerin.
Post your code. It will be helpfull to find out the fault
Regards,
Jerin.
we cant do the compliment if we do so then LEDs initially on and gets off and again we compliment it it again gets on but it should not happen this is state transition happens by what u said...
but i need to stay in the same state.....with out any transition
After your command has been one received as an acknowledgment do off the LED & just initialize it from first onwards.
Regards,
Jerin.
Always check UART receive equal to 'AT+CMTI'. If this code receive, perform to read the message and analyze it.
Example you can do like this GSM Signboard or GSM Switch.
