[SOLVED] Making Led only light at 10v
Shaam123
Newbie level 3
Newbie level 3
Hello,
I have designed a 12v voltage regulator on a breadboard. I can adjust the voltage using a potentiometer. I want to add a led which lights up only when the voltage is 10v. Below that, the led is off. I want to use the led as an indicator that the voltage is equal or more than 10v.
I have attached a schematic of the voltage regulator I have used.
Use LM431 on the output to switch and drive an LED.
Reactions: CataM
    CataM
Would a 10V Zener diode in series to the LED work ?
The led has its own turn-on threshold, a few volts probably. Therefore the zener should be 6-7 V. You'll need to experiment with different combinations.
If you want convenience in adjusting turn-on threshold, the TL431 (as I'm pretty sure post #2 intends) is an adjustable zener.
Be sure to add safety resistors where needed.
