bhanupriya
Newbie level 6
Can any one help me to connect two atmega8 MCs using i2c?....Actualy I'm not familiar wid dis i2c & AVR....So plz help me if u knw......
Sorry I don't use Linux. :-(bhanupriya said:But, how to upload the program to atmega8 in linux??....(we are using parallel port for de connection.....)
Sorry, but the provided link gives me an error and I cannot open it.How leds can be connected for the communication b/t avrs in dis fig....**broken link removed** v need transducers for de communication??...if u knw plz help....
The number of devices that can be connected to the bus is only limited by the bus
capacitance limit of 400 pF and the 7-bit slave address space. A detailed specification of
the electrical characteristics of the TWI is given in “Two-wire Serial Interface Character-
istics” on page 290. Two different sets of specifications are presented there, one
relevant for bus speeds below 100 kHz, and one valid for bus speeds up to 400 kHz.
https://obrazki.elektroda.pl/84_1325215544.jpg can u snd de c code(master & slave) for dis ckt?..
// Program for Master Mode
// Check Code2 for Slave Mode Program
#include<avr/io.h>
#include<util/delay.h>
#include<inttypes.h>
void TWI_start(void);
void TWI_repeated_start(void);
void TWI_init_master(void);
void TWI_write_address(unsigned char);
void TWI_read_address(unsigned char);
void TWI_write_data(unsigned char);
void TWI_read_data(void);
void TWI_stop(void);
unsigned char address=0x20, read=1, write=1;
unsigned char write_data=0x01, recv_data;
int main(void)
_delay_ms(2000);
DDRB=0xff;
TWI_init_master(); // Function to initialize TWI
while(1)
if(write_data==0x00)
write_data=1;
TWI_start(); // Function to send start condition
TWI_write_address(address+write); // Function to write address and data direction bit(write) on SDA
TWI_write_data(write_data); // Function to write data in slave
TWI_stop(); // Function to send stop condition
_delay_ms(10); // Delay of 10 mili second
TWI_start();
TWI_read_address(address+read); // Function to write address and data direction bit(read) on SDA
TWI_read_data(); // Function to read data from slave
TWI_stop();
_delay_ms(1000);
write_data = write_data * 2;
void TWI_init_master(void) // Function to initialize master
TWBR=0x01; // Bit rate
TWSR=(0<<TWPS1)|(0<<TWPS0); // Setting prescalar bits
// SCL freq= F_CPU/(16+2(TWBR).4^TWPS)
// Clear TWI interrupt flag, Put start condition on SDA, Enable TWI
TWCR= (1<<TWINT)|(1<<TWSTA)|(1<<TWEN);
while(!(TWCR & (1<<TWINT))); // Wait till start condition is transmitted
while((TWSR & 0xF8)!= 0x08); // Check for the acknowledgement
while(!(TWCR & (1<<TWINT))); // wait till restart condition is transmitted
while((TWSR & 0xF8)!= 0x10); // Check for the acknoledgement
void TWI_write_address(unsigned char data)
TWDR=data; // Address and write instruction
TWCR=(1<<TWINT)|(1<<TWEN); // Clear TWI interrupt flag,Enable TWI
while (!(TWCR & (1<<TWINT))); // Wait till complete TWDR byte transmitted
while((TWSR & 0xF8)!= 0x18); // Check for the acknoledgement
void TWI_read_address(unsigned char data)
TWDR=data; // Address and read instruction
while (!(TWCR & (1<<TWINT))); // Wait till complete TWDR byte received
while((TWSR & 0xF8)!= 0x40); // Check for the acknoledgement
void TWI_write_data(unsigned char data)
TWDR=data; // put data in TWDR
while((TWSR & 0xF8) != 0x28); // Check for the acknoledgement
while((TWSR & 0xF8) != 0x58); // Check for the acknoledgement
recv_data=TWDR;
PORTB=recv_data;
void TWI_stop(void)
// Clear TWI interrupt flag, Put stop condition on SDA, Enable TWI
TWCR= (1<<TWINT)|(1<<TWEN)|(1<<TWSTO);
while(!(TWCR & (1<<TWSTO))); // Wait till stop condition is transmitted
// Program for Slave mode
#include<avr/io.h>
void TWI_init_slave(void);
void TWI_match_read_slave(void);
void TWI_read_slave(void);
void TWI_match_write_slave(void);
void TWI_write_slave(void);
unsigned char write_data,recv_data;
int main(void)
DDRB=0xff;
TWI_init_slave(); // Function to initilaize slave
while(1)
TWI_match_read_slave(); //Function to match the slave address and slave dirction bit(read)
TWI_read_slave(); // Function to read data
write_data=~recv_data; // Togglem the receive data
TWI_match_write_slave(); //Function to match the slave address and slave dirction bit(write)
TWI_write_slave(); // Function to write data
void TWI_init_slave(void) // Function to initilaize slave
TWAR=0x20; // Fill slave address to TWAR
void TWI_write_slave(void) // Function to write data
TWDR= write_data; // Fill TWDR register whith the data to be sent
TWCR= (1<<TWEN)|(1<<TWINT); // Enable TWI, Clear TWI interrupt flag
while((TWSR & 0xF8) != 0xC0); // Wait for the acknowledgement
void TWI_match_write_slave(void) //Function to match the slave address and slave dirction bit(write)
while((TWSR & 0xF8)!= 0xA8) // Loop till correct acknoledgement have been received
// Get acknowlegement, Enable TWI, Clear TWI interrupt flag
TWCR=(1<<TWEA)|(1<<TWEN)|(1<<TWINT);
while (!(TWCR & (1<<TWINT))); // Wait for TWINT flag
// Clear TWI interrupt flag,Get acknowlegement, Enable TWI
TWCR= (1<<TWINT)|(1<<TWEA)|(1<<TWEN);
while((TWSR & 0xF8)!=0x80); // Wait for acknowledgement
recv_data=TWDR; // Get value from TWDR
PORTB=recv_data; // send the receive value on PORTB
void TWI_match_read_slave(void) //Function to match the slave address and slave dirction bit(read)
while((TWSR & 0xF8)!= 0x60) // Loop till correct acknoledgement have been received
Oh sorry...I found that code...
But can we use 2 ATMEGA8s instead of ATMEGA32s?...If can, what change we need to implement in the code?...
