julian403
Full Member level 5
Transmitter
Serie to Parallel converter + Modulation (QPSK, QAM,APSK,etc ) + iFFT + adding signal+ antenna
I can't understand why there is an IFFT module instead of a FFT in the transmitter.
Let's see what I understand.
Let's figure up that the modulator is an 8PSK and the Serie to Parallel register store 3 bit from the serie path. Thats combination of bit are mapped in a 8 PSK constellation following this (I invented that mapped)
0 0 0 -> angle1
0 0 1 -> angle2
0 1 0 -> angle3
0 1 1 -> angle4
1 0 0 -> angle5
1 0 1 -> angle6
1 1 0 -> angle7
1 1 1 -> angle8
And of course, angle is a constellation phase.
So, we have an output signal in the modulation output with the form:
s(t) = A sin (2 Π f t + angleX)
where angleX can be angle1, angle2, ... depends on the 3-bit combination
But s(t), it's a signal in time domain. Why there is so the IFFT?
What I think the IFFT can do is take more than one SP register and allocated it in:
y(t) = A1 sin (2 Π f + angleX1) + A2 sin (4 Π f + angleX2) +...+ An sin (n 2 Π f + angleXn)
That's correct? all signal has an orthogonal frequency. But I developed an OFDM modulator without an IFFT. of course, this is all generated by a DSP and there isn't an oscilator for every frecuency.
0 0 0 -> angle1
0 0 1 -> angle2
0 1 0 -> angle3
0 1 1 -> angle4
1 0 0 -> angle5
1 0 1 -> angle6
1 1 0 -> angle7
1 1 1 -> angle8
