daryoosh23
Newbie level 3
In a text editor environment I have a set of chemical reactions which are represented as "rxn[A,3B,C,K]" indicating "A+3B-->C" with rate K.
I want to write a few lines of code for converting it from the prior format to the secenond format in Microsoft word or even Latex. I want to put the rate value "K" on the top of --> (arrow) in the second format. Can you help me?
