cloudsky
Newbie
Hello experts,
I'm a student and I'm trying to study how an op-amp works.
I want to make an amplifier circuit using a thermocouple (TC) as the input (K-type, range about 0 - 50 mV). The output I expect is about several V. In the case of this LM358P that I'm using, I expect the output to be from 0 - 2 V (for a connection with Arduino to calculate the temperature later).
Here is the circuit diagram I found on the internet. I made the circuit as shown below.
I think the circuit works correctly because what I received in the output is ~ 6V and reducing (due to the feedback of the R2=100k to the 2- pin) when I used a 12V supplier to the Vcc+.
Here is the simulation that I also tried to understand the circuit.
The question is, how can I change or improve anything to receive the output (~ 0 ->1V) that also changes with the input (from TC ~0 - 50 mV)?
Thank you so much for your time and support.
If it's possible, I would like to send you a cup of coffee as my gratitude.
the simulation I forgot
--- Updated ---
