tennythomas
Member level 2
The module (WLAN + Bluetooth) is connected to 2.4 GHz antenna (on the other board) via the connector through the 50 ohm (impedance) RF trace.
Should i add some impedance matching circuit to maintain 50 ohm impedance along the RF trace which connects the module, the connector and 2.4 GHz antenna? If so, what is the circuit?
Thanks in advance.
Thanks in advance.
