ord
I have an application where a low level signal from a chemical sensor is being buffered by a high impedance op amp. I need to find a way to maintain the high impedance when the power is removed, otherwise it shorts the sensor and causes it to take a long time to recover when power is restored. As it is now, when the op amp is not powered current leaks into the inputs. I need to keep the leakage below 1nA, preferably near the 1pA level.
I was looking for a mosfet that I could use to switch one of the leads, but can't find any with low enough leakage at 0V on the gate.
I can't use a relay because I don't have enough power available to keep it energized.
Hoping for some ideas!
Thanks!
Thanks!
