Yes and no.+/- 50 us is a large tolerance
It's not clear to me how a phase locked circuit can generate a constant "pre-delay" while the frequency may change from 5 to 60Hz.Consider a tuneable precision one-shot where the trailing edge is phase-locked to the limited AC logic signal
In a Type II PLL, the inputs are edge-sensitive, meaning they are sensitive to either rising or falling edges of the input signals. Here are the key pointsHi,
A PLL can generate constant phase .. but how constant time.
Klaus
This does not answer my question on how to generate the constant 430us timing .. considering the 5..60Hz input frequency.
I surely understand how a PLL works.
Klaus
When the required tolerance on delay is +/-20%, a trimmer adjustment with a stable supply can easily achieve this or even a few %.Having designed one of those (on a now dead technology) I can
say there's no such thing as a precision one-shot of that style.
Sloppy comparator, even if you used 1% R and 5% C you are stuck
with the datasheet variability of timing which is not great. That's
where you start thinking about clocks, counters and complexity.
And wander far from (say it with me now)....
But for somebody doing digital power converter control this is
probably almost a freebie.
Thanks for your effort.Forgive me for not explaining.
