hithesh123
Full Member level 6
Why is magnetizing inductance represented in parallel to the actual inductance?
In a flyback transformer, the magnetizing inductance in series with the leakage inductance together represent the real primary side?
Also, why does the secondary voltage get reflected to the primary side?
If Mosfet is the switch, then the voltage will be Drain Voltage+reflected voltage.
