Magnetic Polarity Indicator
Hexy
Newbie level 2
Newbie level 2
Belarus
Bring to your attention a curious device invented by me - an indicator of polarity of the magnet. That inspired me to create it: the construction of my **broken link removed** as well as the desire to practice to get acquainted with modern operational amplifiers (current does not require a bipolar power supply, which is very convenient).
Works this device this: when power is on (battery 6F22 9 V) green light. If near the **broken link removed** no magnet, the blue and red LEDs do not light.
When approaching the north pole of a magnet to the sensor lights up blue LED
and southern - red.
If you rotate the rotor brushless motor near the sensor, then the blue and red lights alternate, corresponding to passing by the poles of a magnet - it is convenient for determining the number of poles.
Circuit and photo of the PCB - **broken link removed**
what chip did you use?
what is the range? Or how strong does the magnet need to be?
Hall sensor (4 pin) from FDD 3.5''
can replace expensive bridge VHE-101B
I checked with ferrite and
neodymium magnets ->>
and the ring magnet of FDD motor
distance ~ 0.5 cm
comparator = LM358
