Murugesh_89
Full Member level 5
If a coil which has a number of turns = 400, resistance = 50 is connected across the 5V supply, then 100mA of current flows through the coil and it will create a magnetic field (M1).
If we increase the number of turns to 480, which will increase the resistance to 60, is connected across the same 5V source then a current of 83mA is flowing through the coil which will create a magnetic field (M2).
Since the number of turns and hence the inductance of coil is higher in M2 than M1, will the M2 is higher than M1? or
since the current through the coil is greater in M1 than M2, will the M1 is higher than M2?
Please give me clear explanation...
