[SOLVED] magnet wire parasitic properties
Zak28
Advanced Member level 2
Were is a well established chart depicting parasitic self capacity of varying magnet wire sizes per unit of length?
Much akin to wire having self induction but in this case capacitance.
capacitance varies heavily with winding structure ...! there is no magic figure ...
Reactions: Zak28
    Zak28
Snelling, Soft Ferrites, paragraph 11.6 The Self Capacitance of a Winding does detail calculations of different winding configurations. The 1969 book is out of print, but available on archive.org.
Reactions: Zak28
    Zak28
The text depicts formuli per winding arrangement consolidating a large area by using formuli instead.
There is very practical standardized wire information tables not commonly available elsewhere including insulation thickness. But ferrites aren't soft materials.
Ferrites are soft or hard depends on their magnetic properties. Yes, they are not "soft" materials, because you will take lots of time to cut one.
Just like soft iron does not store magnetism, it produces lots of induction but "retentivity" or "coercivity" is small.
Same is the case for "soft ferrites".
They are metal oxides (iron, nickel, etc etc) and are produced by sintering and heat treatment. Mechanically they are hard and brittle. Handle with care.
More important than their self-capacitance, is the inter turn capacitance.
In this case you are considering two turns of the same solenoid as a capacitor but they are electrically connected.
Just like a straight wire has some self inuctance but what you are perhaps interested is the inductance of the solenoid.
Both depend on the geometry and less on the size of the wire.
Reactions: Zak28
    Zak28
Self capacitance in the Snelling book means inter turn capacitance.
Reactions: Zak28
    Zak28
