lile
Newbie level 2
magma Segmentation fault
# ----------------- Mantle Log -----------------
Copyright (C) 1997-2005 Magma Design Automation Inc.
# MAGMA DESIGN AUTOMATION, INC. ("MAGMA")
# MAGMA CONFIDENTIAL AND PROPRIETARY INFORMATION
# IF YOU ARE NOT AN "AUTHORIZED USER"
# UNDER A MAGMA SOFTWARE LICENSE AGREEMENT
# STOP
# RETURN THIS FILE IMMEDIATELY TO MAGMA (408-565-7500)
#OR MAGMA WILL ENFORCE ITS RIGHTS TO THE FULLEST EXTENT OF THE LAW
#Magma Confidential. All rights reserved.
mantle version 2005.03.32-linux24_x86 (compiled May 12 2005 02:31:14)
CMD-20 WARNING: This build of mantle has not passed Magma's full quality of results testing. This build should only be used in emergency situations and may contain known bugs or other problems. Please use at your own risk and with proper discretion. You may contact a Magma representative to receive a fully tested release of this software (this is a red build).
LIC-1 Setting default license file to '/EDA/magma/2005_05_12.0327/common/license'.
LIC-12 The following features have been checked out: BLAST_VIEW BLAST_WRAP BLAST_SPEED BLAST_BUILDER BLAST_PLAN BLAST_PLANPRO BLAST_CREATE BLAST_PLANSVP BLAST_RTL BLAST_LOGIC BLAST_FPGA BLAST_FPGA_XILINX BLAST_FPGA_ACTEL BLAST_FPGA_ALTERA BLAST_FUSION_APX DPX BLAST_FUSION_MVDD_APX BLAST_POWER BLAST_YIELD BLAST_MT2 BLAST_MT4 BLAST_MTU BLAST_SI BLAST_RAIL BLAST_CREATE_SA BLAST_CREATE_SA_FARADAY BLAST_FUSION_SA BLAST_FUSION_SA_FARADAY RGEN BLAST_FLIPCHIP QUARTZ_TIME BLAST_RAIL_NX QUARTZ_RC BLAST_CREATE_SA_EASIC BLAST_TEST
SIG-1 Mantle process caught a fatal exception
SIG-1 Details:
SIG-1 Process with PID=4460 executing /EDA/magma/2005_05_12.0327/linux24_x86/bin/mantle
SIG-1 caught signal=11 (Segmentation fault)
SIG-1 code=1: Signal was generated by kernel.
SIG-1 Additional info: address not mapped to object
SIG-1 Faulting addr=0x5906dbc
SIG-1 end-of-stack=0xbf800294
SIG-1 Memory usage:
SIG-1 overall peak reserved=1347584
SIG-1 currently reserved=1331200
SIG-1 Could not determine free swap space on this architecture
who can help me?
# STOP
SIG-1 Details:
SIG-1 Memory usage:
who can help me?
