bluesman
Newbie level 1
I use modelsim XE/starter 5,6a :I have a problem by launching application for processes : "Simulate post-place & route vhdl model", "Simulate post map vhdl model" and "Simulate post translate vhdl module: it appears in red : #invalid command name "xxx_tbw.ndo","xxx_tbw.mdo","xxx_tbw.tdo". Then it appears in blue:" Warning: a modelsim starter license was detected and will be used, even though you have installed modelsim XE.You should obtain an XE license in order to access modelsim XE's full capabilities".
In ise console :ERROR: hidden remap failed.What does ti mean? What should I do? I have implemented only a 8bit shift register!
I uninstalled and reinstalled modelsim XE STARTER 5.6a but the blue message still appeared...why? I have done an exercise following a tutorial about a counter : it worked normally,without this problem!
THANK’S for your interesting!
Could you send your answer to trevisan_marco@yahoo.it please?
