jstefanop
Member level 2
So I'm making a PCB that has an M.2 PCIE X4 connector (M key version). I have the schematic ready to go, but have no idea how to make an accurate outline for the actual connector and pads. Is there a M.2 library file that already has the connector created that I can use to edit?
(worst case I need just the outline, and I can manually create the pads as a PCB footprint)
Link bellow is essentially what I need, but this is obviously not for PCB software so can't import it. (I can use either Altium or Eagle).
https://grabcad.com/library/m-2-ssd-drive-1
