[SOLVED] Lynxmotion ALA5 arm robo help plzzzzzz..
cyanpraveen
Junior Member level 3
Does any one have idea how to program Lynxmotion ALA5 robo arm for simple pick and drop operation.
Is it possible to make a sequence running in a loop using AL5A that arm need to pick a object from one place and drop it on other place using lynx SSC-32 terminal software. If means wats de possible way to calculate time delay for each action.
If not wat is software i need to use for it..
I just can able to make only one sequence at a time using macro. if i do the two sequence in same macro it executes the second sequence before it completes the first sequence fully..
Thanks guys for ur help...
