[SOLVED] lvs file for cmrf8sf (130nm tech)
nana_7488
Member level 1
Member level 1
Hi
I'm doing layout in 130nm tech using Calibre. I got a compilation error when I run LVS:
undefined layer name parameter: _____NO_VALID_METAL_STACK_OPTION_DEFINED_____.
If someone have any idea to solve this, or have cmrf8sf.lvs.cal for this PDK.
Thanks
Hi nana_7488,
This error is caused because you have configured the metal stack wrongly.
When invoking the Calibre, pay attention when setting the value of the following switches:
1- Last metal:
2- MG Process:
3- NUMMetal:
I´m sure that you have added a wrong information in one of these fields. If you still have doubts regarding which values you should correct, take a look in page “4” of Calibre_LVS_relnotes.pdf. There you can find all possible combinations of mentioned variables. Ok?! ;-)
Regards.
Hi Palmeiras
Thanks for your reply. I have a look at the lvs file, and I've changed the value of what you have mention. One more question, do I need to setting the value for this
Valid settings are:
// LM BEOL MA BEOL LD BEOL AM BEOL
// 5 LM NOMG 6 MA NOMG 5 LD NOMG 7 AM NOMG
// 6 LM NOMG 7 MA NOMG 6 LD NOMG
// 7 LM NOMG 7 MA MG 7 LD NOMG
// 8 LM NOMG 8 MA MG 8 LD MG
// 7 LM MG 8 MA NOMG 8 LD NOMG
// 8 LM MG
Thanks again.
There is no need to change the rules, all the variables that can be set in Calibre LVS deck are available in Calibre interactive clicking on Setup>Set Environment, valid values are those described in the PDF mentioned by palmeiras
if you are running batch still no need to change the rules as those variables can be set in the shell environment
Hi nana_7488,
Yes... this is the right possible combinations.
For instance:
1- Last metal: MA
2- MG process: MG
3- n metal: 8.
Have you tried to run LVS with such values?
Best regards.
I've tried to define the value in 'set the environment' but I can't be able to modify the undefined value. Would you explain how to do it?Thanks
---------- Post added at 22:35 ---------- Previous post was at 22:33 ----------
Hi nana_7488,
For instance:
1- Last metal: MA
2- MG process: MG
3- n metal: 8.
Best regards.
Hi
I already try to changed like that, but still have the same error.
What is the metal stack of your process?
And what is the last metal?
If this error continues, maybe the suggestion above is not valid.
So... check in your manual and with your foundry what is the right combination. I´m sure that if you use the proper combination of these three variables, you are able to run LVS properly.
Hi
if you are talking about Calibre Interactive, the entry method depends on the exact version of Calibre; in general there should be a runset value column where you enter a value overwriting the default (set by the shell or the runset) and a box you have to tick to enable that value to overwrite the default; all you enter can be saved into a default runset
