LVDS frequency and impedence
zionico90
Member level 2
Member level 2
I should simulate a Twisted pair using low voltage differential signal. I know this parameters for the signal:
Trise=tfall= 1.2 ns
Working at 200 mb/s
Which is the frequency in Mhz?25MHz?
I assume you mean 200 Mega-bits-per-second. That's 200MHz; I don't know how you got 25MHz. If you want to know the bandwidth of your edges, that's :
F=0.35/tr==>292Mhz.
Just a quibble. A bit rate of 200 Mbits per second has a fundamental frequency of 100 MHz. A string of alternating 1-0-1-0... at 200 MBits per second would look like a 100 MHz signal with harmonics defined by the rise and fall times.
It Is particular signal in which the clock data is 01001101001
