Daniel Mog
Newbie
I have a placed and routed design in Innovus, from which I extracted an .OAS file - I ran Calibre for DRC and the following violation popped up for std cells as well as filler/dcap cells in my design. At first I though this has something to do with the tap cells, but the description doesn't indicate any issue with them - but rather that there's an issue with the text(?). I would appreciate an explanation for this violation (as well as what the CB, CB2_ALL and UBM_ALL are, what the meaning of the HiR resistor is and how I can deal with these violations):
LUP.WARN.1 { @ Voltage high text or voltage marker layer must exist in CB, CB2_ALL and UBM_ALL in chip level. Connection is broken by HiR resistor.
Exception: 1. SEALRING_ALL 2. Connections with "DUMMY_PAD_TEXT" on the same net, when "DEFINE_PAD_BY_TEXT" is turned on. 3. Connections with "D2D_INT_CDM05V_PAD_TEXT" on the same net, when "DEFINE_PAD_BY_TEXT" is turned on. 4. Connections with "D2D_INT_CDM10V_PAD_TEXT" on the same net, when "DEFINE_PAD_BY_TEXT" is turned on. 5. Connections with "D2D_INT_CDM50V_PAD_TEXT" on the same net, when "DEFINE_PAD_BY_TEXT" is turned on. When turn on option "DEFINE_PAD_BY_TEXT" DRC checks voltage text on power/ground/signal virtual pad in cell level When turn off option "DEFINE_PAD_BY_TEXT" DRC checks all of CB, CB2_ALL and UBM_ALL in chip level
LUP_NW_VOL_WARN NOT NW_PAD_DBT_WAIVE
LUP_RW_VOL_WARN NOT RW_PAD_DBT_WAIVE
LUP_PSD_VOL_WARN NOT PSD_PAD_DBT_WAIVE
LUP_NSD_VOL_WARN NOT NSD_PAD_DBT_WAIVE
LUP_PSTP_VOL_WARN NOT PSTP_PAD_DBT_WAIVE
LUP_NSTP_VOL_WARN NOT NSTP_PAD_DBT_WAIVE
