doupg
Junior Member level 1
Hi Everybody,
I'm using this command on a spice simulation (LTSpice):
.step param Rmin list 1 1k
i.e. I'm just doing an analysis for which I want to analyze the current through a resistor (Rmin) for two different situations: Rmin=1ohm and Rmin=1Kohms.
I plot the current and can I see the two different waveforms.
With Right Mouse Button I can choose "Select Steps" and pick only one waveform (either for Rmin=1ohms or Rmin=1Kohm) if I want.
For my analysis I want to see both waveforms at the same time.
Here comes the question:
when I place the cursors how can I assign let's say cursor1 for Rmin=1ohm and cursor2 for Rmin=1kohm, or if I want to use only one cursor how do I indicate the cursor which step (Rmin=10ohm or Rmin=1kohm) to evaluate and change between them. There must be a short key, but I'm missing it.
Thank you very much!
