LTspice simulation of Two transistor forward wont run..."singular matrix" error
T
treez
Newbie level 1
Do you know why this LTspice sim of a two transistor forward wont run? The error message says “singular matrix node N029”.
  • two tran forward LTC3705 LTC3706.txt
i'm not used to reviewing spice through the netlist
after searching your schematic symbols, i found no symbol for ground
spice requires a reference - there must be a ground symbol somewhere.
can you post the schematic?
Reactions: treez
    T
Thanks yes, please find the schem...also, the .txt in the top post, if converted to .asc , will give the schem if opened in LTspice
  • two tran forward LTC3705 LTC370.pdf
Signal "SG" seems to go nowhere and the way Linear
Tech makes macromodels, this might be a node with
nothing but code attached?
Reactions: treez
    T
resistor R22 is 100r
i'm surprised spice didn't flag a syntax error
suggest you remove the r
Reactions: treez
    T
Thanks, ive got a little farther now, but not much further...still no 24v, 100w
The R22 is 100R and i feel will it be ok like that since its only a snubber resistor
  • two tran forward LTC3705 LTC3706_2.TXT
Maybe you should look at the command "K L1 L2 1". Maybe you'd need to change the K to K2.
Thanks, as long as the K's all have different numbers than its OK.
Check your connection of D6 and C10 to Boost and Ts pins of 3705. You've made a mistake there. The diode should be connected to the boost pin while the cap should be across the two pins mentioned.
Reactions: treez
    T
Thanks yes, that was picked up and the re-hash is in #6 above...though it still doesnt work
Please post your updated schematic.
