LTSPICE help required
xyz9915
Member level 4
Member level 4
Pakistan
SMES.jpgHello,
In a superconducting magnetic energy storage (SMES) project, I need some help that how to develop a system using LTSPICE if a voltage sag occur the spice circuit balance this voltage drop by discharging energy stored in the SMES coil.
The SMES performance is determined by its controller
The demanded active and reactive power, needed to support power system performance as measured by
voltage, stabilizing power oscillation and improving power transfer, is determined by the control system based on deviations in voltage, frequency, and current.
This control system controls the firing angles according to the signals of demanded reactive and active powers.
My question is that how to develop a system using LTSPICE if a voltage sag occur the spice circuit balance this voltage drop by discharging energy stored in the SMES coil.
Thanks
