usama14
Member level 5
Hi all.
I'm using LTC4367 for reverse polarity, OV and UV protection. I'm using the FDMD84100 Dual N channel Mosfets and the input voltage is 50V. However, when connected without any load, the output voltage is all OK at the beginning but then it gradually decreases towards zero. Also my transistors have been burnt in most cases and I've tried changing the IC and the transistors countless times. My output current requirement is 7A. OV is 58V and UV is 5V. I've used the resistors according to these values. Also, I've tested both in open load and also by attaching the load, the result is the same.
I'm attaching my schematic.
Kindly help as I'm stuck at this stage for a very long time now. Thankyou!
