ElecDesigner
Member level 5
- Joined
- Jul 22, 2014
- Messages
- 94
- Helped
- 4
- Reputation
- 8
- Reaction score
- 5
- Trophy points
- 1,288
- Activity points
- 2,190
I have a board that was designed by someone else but it never worked and the designed left the company. Its basically a bunch of opamp circuits and I have narrowed the problem down to a 1.8V negative bias on a LT6231 op-amp.
The op amp is supplied by +5/-5V rails.
One strange thing I notice is that the exposed copper pad has been connected to mid rail (ground) on the PCB. In the datasheet for the part it indicates that the pad is connected to V- internally. Its clearly not however, as the combined effect of the chip and PCB would cause a direct short between -5V and ground.
http://cds.linear.com/docs/en/datasheet/623012fc.pdf
However does anything have any thoughts as to if this misconnection on the PCB (thermal pad to GND instead of -5V) might cause the offset I am seeing.
